I have a Kenmore 106.56566400 that is not producing ice. The control board light blinks twice, pause, repeats when the door is open. If I close the flap manually the light remains solid/red. I checked the black water fill hose and it's not frozen as best as I can tell. I do get water to the front of refrigerator where you fill up a glass. I manually poured water into the water mold and the ice maker never kicked out the ice cubes. The white levers attached to the rotating rod are pointed straight towards the front - perhaps slightly up.
I've read of people switching the wires and pushing on the water lever in front to trigger the water to enter the ice maker (would appreciate a diagram or explanation on how to achieve that).
Any other ideas?
