Dishwasher heats up, but not enough to dry the dishes.
Here are your parts Replacement parts for General Electric GSD2030F00WW Dishwasher | AppliancePartsPros.comUnplug or remove power from the unit. Remove the wires from on side of the heater and check it with a meter. Usually they are around 20 ohms. If OK Check the wires from the timer down to the heater. If OK Reattach the heater, plug it in and check that the heater gets 120 volts when it should be heating. Could be a bad set of timer contacts. IF OK Check that the vent is open. |
THIS FORUM IS DEAD!!!!!!! |
