Dryer will not dry, but will rotate with no heat. How do I repair? Took the panel off the back but nothing looks out of the ordinary. Could it be the heating coil and if so, where is it located?
You should see the heater element inside a metal container on the right hand side. You need to check continuity of the thermal fuse and the heating element. Here is a site which will show you some pictures. If you are not conversant with a multi meter try to find someone who has one to help you. Whirlpool Dryer PartsWhile you have the back off take off the blower cover and make sure the lint chute is thoroughly cleaned, including the blower. Good luck.
