Douglas Collins
#1 Posted : Friday, October 19, 2007 7:07:03 AM(UTC)
Douglas Collins
My washer fills but will not go to the next cycle. If I hold a screwdriver in the door switch it will operate. I was going to check the switch, but cannot figure out how to get the top open. Also I can put something heavy on the top and it will work. Will someone please help a old man out. How do I get into this thing?
Thanks,
Doug:confused:
ApplianceJunk
#2 Posted : Friday, October 19, 2007 9:32:58 AM(UTC)
ApplianceJunk
To replace the lid switch you will need to remove the washer cabinet.
The top, front and sides all come off as one.
What happens with the lid switchs is the plastic part of the switch that the screws run into crack. This lets the switch drop down a little to far so when the lid is closed it does not trip the switch.
You will need to remove the cabinet and replace the lid switch.
This video will show you how to remove the cabinet.
Video: How to Remove Direct Drive Washer Cabinet
Douglas Collins
#3 Posted : Friday, October 19, 2007 10:42:27 AM(UTC)
Douglas Collins
Thanks.
How do I get the video to play?
ApplianceJunk
#4 Posted : Friday, October 19, 2007 12:44:07 PM(UTC)
ApplianceJunk
Click the play button on the bottom left after it loads.
If you have a slow dial up connection it may take some time to load.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
