I have replaced the control board and control panel board,(they come as a set) twice in the last six months. Now, when I select any wash button then push the start button, the wash button blinks and nothing happens. I can push #4 & #8 buttons at the same time and sometimes it will go into diagnostic mode with lights flashing, but still cannot do any diagnostic tests, no buttons work. Eventually, all the lights will go out and I can try it again with same results. Hope someone has seen this before.
I think I found the problem. The whole panel flexes when I close the door and I think it is damaging the keypad.
