ED12
#1 Posted : Monday, December 20, 2010 10:52:44 AM(UTC)
ED12
My glass top has cracked for the 2nd time near the large 8" right burner.
I have replaced the glass top again, but have noticed the sometimes I have no control of this burner, even at the lowest setting it will burn food.
With the last top replacement, it was recomended to replace the infinite sw (since this is not available for the 8" burner) I replaced the 8" limiter kit (twice) neither kit works at all. If I install the original one, it works but still have no control. Where do I go from here?
#2 Posted : Monday, December 20, 2010 12:36:17 PM(UTC)
Originally Posted by: ED12 Go to Quoted Post
...it was recomended to replace the infinite sw (since this is not available for the 8" burner)...
Who told you that this switch is not available?
- The infinite switch for the large element Part number: AP4101874
ED12
#3 Posted : Monday, December 20, 2010 12:49:14 PM(UTC)
ED12
Can you access order #1512625? This has the details.
ED12
#4 Posted : Monday, December 20, 2010 1:33:27 PM(UTC)
ED12
Ok sorry, my mistake. Let me start from scratch. My 8" burner (most of the time) is uncontrolable. It most of the time, glows solid red & does not turn off even at the lowest setting. Can you tell me what I should replace? I just put in another glass that cracked in the same area and I wanted to fix the "control problem" of this burner.
#5 Posted : Monday, December 20, 2010 5:29:34 PM(UTC)
...I replaced the 8" limiter kit (twice) neither kit works at all...
When did you replace it last time?
What is the part number of the limiter kit you installed?
What is the serial number of the range?
P.S. I'm just a volunteer on this forum and I do not work for Appliance Parts Pros.
ED12
#6 Posted : Thursday, December 23, 2010 12:21:48 PM(UTC)
ED12
Kit replaced twice in last 2 weeks. PN AP4012912. SN or range 13292870UZ.
#7 Posted : Friday, December 24, 2010 4:15:59 PM(UTC)
According to the part number you posted this is actually the whole heating element kit and not just a limiter kit as you said previously. This element wiring can be different with the old one and that's why it probably did not work.
Most likely the problem is a bad infinite switch and hopefully the new switch will fix this problem.
P.S. Do not rush with the heating element kit return. You might need it too.
