7 Pages<12345>»
JoyKimbrell
#21 Posted : Wednesday, December 15, 2010 7:28:26 AM(UTC)
JoyKimbrell
Thank you for your help! I appreciate it. Part ordered and my husband is going to give it a try.
Interestingly, he talked to a rep at Whirlpool and then the corporate office and they deny knowing anything about a problem with the cleaning cycle killing KitchenAid ovens.....unbelievable! I'm going to write them a letter and direct them to this forum and the one on facebook.
#22 Posted : Wednesday, December 15, 2010 12:43:53 PM(UTC)
You are welcome Joy. Keep us posted.
JoyKimbrell
#23 Posted : Friday, December 17, 2010 2:09:19 PM(UTC)
JoyKimbrell
Wow....parts (thermal fuse & blower) came in (we had them sent two day delivery) and my husband replaced the parts with no problem. Oven is working again. What a service you talented people (Gene & teocjr) are providing on here!! You saved us a ton of money!!! Thank you, thank you, thank you!!
#24 Posted : Friday, December 17, 2010 2:26:16 PM(UTC)
You are welcome Joy. We are glad you were able to fix it.
Thank you for your good words.
Happy Holidays!
fredkimbrell
#25 Posted : Monday, December 20, 2010 5:42:20 AM(UTC)
fredkimbrell
Happy Holidays!
Again, many thanks to Gene and teocjr for info on this problem. I posted a YouTube video YouTube - KitchenAid Superba Wall Oven DIY Repair that may be helpful to DIY folks.
PaulNewmansGal
#26 Posted : Thursday, January 27, 2011 10:51:30 AM(UTC)
PaulNewmansGal
Joy...let me know what happens with your corporate letter! It is clear that this is a widespread problem.
I have followed this thread and have removed control panel, got top oven open, found model number : KEBS278DSS6
I am in the middle of this repair now and would like to know how I can tell if my thermal fuse is blown? Forgive my ignorance. Should I just order the part and see if it works with a new one? Thank you for all of your posts and help! It is much appreciated.
~Carrie
#27 Posted : Thursday, January 27, 2011 12:29:03 PM(UTC)
Carrie,
If the display is blank then you have to replace both thermal fuses. One for the control panel. You can identify it by the following picture. The second thermal fuse is for the oven heating circuit. It is located on the back of the oven. So the oven has to be removed from the cabinet to access it.
- The control panel thermal fuse Part number: AP3777386
- The upper oven thermal fuse Part number: AP3879224
PaulNewmansGal
#28 Posted : Thursday, January 27, 2011 3:47:39 PM(UTC)
PaulNewmansGal
I have purchased the parts from a local parts store and am preparing to remove the oven. The thermal fuse was clearly easy to replace but I am now trying to figure out how to take the door off the oven to pull it out and replace the other one. Any pointers on removing the door? THANK YOU!!!!!!!!!
Never mind...just found users guide online. http://shared.whirlpoolc...0Guide%20-%204450571.pdf
Wish me luck on the rest!
PaulNewmansGal
#29 Posted : Thursday, January 27, 2011 6:30:03 PM(UTC)
PaulNewmansGal
I have replaced the thermal fuse in the control panel as well as the thermal shutdown control fuse. Upon turning the breaker back on I am now receiving an error code of PF-27. ANY help is appreciated. Everything has been put back together! ARRRGGGHHHHHHH! I was so impressed with myself! :(
~Carrie
Update: Receiving alternating PF-27 and F2-EO error messages. I understand that the PF-27 says I need an entirely new control board. F2-EO means keypad is not connected. Where do I ensure that the keypad is connected?
#30 Posted : Friday, January 28, 2011 1:40:35 PM(UTC)
Open the control panel and check how the control panel ribbon cable is plugged onto the control board.
7 Pages<12345>»
