Vampire
#1 Posted : Saturday, March 12, 2011 11:42:45 AM(UTC)
Vampire
I started a wash it fills and agitates, runs like its suppose too, then it shuts off and doesnt spin the water just stayed in washer, i had to manually remove the water. I moved the button to different wash types and it does the same thing, I cant get it to spin and remove the water.
sidfink43
#2 Posted : Sunday, March 13, 2011 7:52:42 AM(UTC)
sidfink43
Start by checking the lid switch. If you have water in the tub you can bypass the lid switch, and if that is the problem it will allow the machine to drain and spin, but since the lid switch is a safety item you should replace it.
Vampire
#3 Posted : Sunday, March 13, 2011 10:57:11 AM(UTC)
Vampire
Thank you it is the switch, now i just have to figure out how to get it out any sugestions on how to take it apart. Thanks again
sidfink43
#4 Posted : Sunday, March 13, 2011 12:48:29 PM(UTC)
sidfink43
This video will show you how to get the cabinet off, after that, piece of cake, except getting the cabinet back on takes some patience.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Vampire
#5 Posted : Sunday, March 13, 2011 2:34:12 PM(UTC)
Vampire
thanks i was able to do that, thanks so much, now to put it back together. Thanks again.
