I started a wash it fills and agitates, runs like its suppose too, then it shuts off and doesnt spin the water just stayed in washer, i had to manually remove the water. I moved the button to different wash types and it does the same thing, I cant get it to spin and remove the water.
Start by checking the lid switch. If you have water in the tub you can bypass the lid switch, and if that is the problem it will allow the machine to drain and spin, but since the lid switch is a safety item you should replace it.
Thank you it is the switch, now i just have to figure out how to get it out any sugestions on how to take it apart. Thanks again
thanks i was able to do that, thanks so much, now to put it back together. Thanks again.
