Load the dryer and turn starter switch, but it hums. Popped the top off dryer, turn the start switch, and can turn drum by hand counter-clockwise and it will turn and run. Is it the starter, and so, where is it located and price for part.
Most likely the motor is in the motor itself. If you can get it started by hand and it works the bearing in the motor pulley may be seizing.
Nat
