AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Very Loud Uuugh-Uuugh Noise During Agitation Cycle
Our Maytag LAT9306BGE makes a very loud uuugh-uuugh noise during the agitation cycle only (sounds like someone is being punched in the stomach). There are no other unusual sounds during the other cycles. The machine was used for 2 years. Can we continue to use it without causing damage the machine? Would a little grease help? We would really like to hear your professional advice - thanks!
Remove the front panel, there are two screws on the bottom to remove. Check for a bad belt. If ok, check where the noise is comong from and post back.
Originally Posted by: richappy  Remove the front panel, there are two screws on the bottom to remove. Check for a bad belt. If ok, check where the noise is comong from and post back. Hi Richappy, I visually inspected the shaft pulley belt and carefully felt the pump belt and both seem okay; no signs of tear, etc. The noise is loudest at the machine’s rear upper right. What do you suggest?
You might have a loose spin basket,or something stuck in the tub. Also, bad/busted spin bearing a possibility.
Originally Posted by: richappy  You might have a loose spin basket,or something stuck in the tub. Also, bad/busted spin bearing a possibility. Thanks for your reply. (1) How can I check to see if something is stuck in the tub - remove the back panel? (2) Excuse me for the question, what part of the machine is called the spin basket? (3) How can I tell if it's loose? Thanks so much!
I would re-post this as a possible transmission problem.
Washer Repair
