dabrams
#1 Posted : Monday, December 29, 2008 12:07:43 AM(UTC)
dabrams
Our Maytag LAT9306BGE makes a very loud uuugh-uuugh noise during the agitation cycle only (sounds like someone is being punched in the stomach). There are no other unusual sounds during the other cycles. The machine was used for 2 years. Can we continue to use it without causing damage the machine? Would a little grease help? We would really like to hear your professional advice - thanks!
#2 Posted : Monday, December 29, 2008 4:49:45 AM(UTC)
Remove the front panel, there are two screws on the bottom to remove.
Check for a bad belt. If ok, check where the noise is comong from and post back.
dabrams
#3 Posted : Tuesday, December 30, 2008 12:02:43 AM(UTC)
dabrams
Hi Richappy,
I visually inspected the shaft pulley belt and carefully felt the pump belt and both seem okay; no signs of tear, etc.
The noise is loudest at the machine’s rear upper right.
What do you suggest?
#4 Posted : Tuesday, December 30, 2008 12:26:09 AM(UTC)
You might have a loose spin basket,or something stuck in the tub. Also, bad/busted spin bearing a possibility.
dabrams
#5 Posted : Tuesday, December 30, 2008 12:45:29 AM(UTC)
dabrams
Thanks for your reply.
(1) How can I check to see if something is stuck in the tub - remove the back panel?
(2) Excuse me for the question, what part of the machine is called the spin basket? (3) How can I tell if it's loose?
Thanks so much!
#6 Posted : Tuesday, December 30, 2008 2:38:17 AM(UTC)
I would re-post this as a possible transmission problem.
