force73
#1 Posted : Saturday, December 27, 2008 1:32:36 PM(UTC)
force73
My unit just stopped when I was changing out the loads went to restart and when I shut the door I could hear a humming noise. Hit the start button nothing happened turn the dial to off and humming stops turn dial to any position but off humming comes back still no start now humming has stopped completely I do not have wiring diagram was not with machine but I do have the capabilities to test electrical any input would be greatly appreciated
kayakcrzy
#2 Posted : Sunday, December 28, 2008 2:22:58 PM(UTC)
kayakcrzy
You most likely have a bad motor. Open the door of the dryer , and turn the drum. If the drum turns, it is most likely a bad motor. If it does not, it still could be a bad motor, and it could have a garment stuck in the blower wheel. The front has to come off to view the blower wheeel. Tom
Dryer hums, motor will turn by hand (Dryer Repair)
by 123456123456LF 1/14/2017 5:52:12 AM(UTC)
Dryer hums, won't start (Dryer Repair)
by galerian 1/6/2016 8:52:13 AM(UTC)
Dryer hums, won't spin (Dryer Repair)
by jwieland 4/24/2014 2:47:30 AM(UTC)
Roper Dryer hums Does not start (Dryer Repair)
by nkaufman 1/10/2014 4:13:57 AM(UTC)
Dryer hums won't start (Dryer Repair)
by HOYTGRIMES 12/10/2013 4:06:40 PM(UTC)
Dryer hums but won't stay on (Dryer Repair)
by Sdnighs 8/1/2013 10:31:18 AM(UTC)
dryer humming. buzzer wont stop. drum will start if you turn manually (Dryer Repair)
by ray lotta 7/22/2013 4:45:34 PM(UTC)
push start, dryer hums but doesn't tumble (Dryer Repair)
by Peppermint672 7/4/2013 10:35:44 PM(UTC)
Dryer hums and won't start (Dryer Repair)
by u71589 9/26/2012 2:39:56 PM(UTC)
Ge Dryer hums but won't start (Dryer Repair)
by douglas_kb 6/1/2012 6:54:01 AM(UTC)
Ge Dryer Hums But Won't Start (Dryer Repair)
by douglas_kb 5/27/2012 12:04:27 PM(UTC)
Maytag Dryer hums, won't start. (Dryer Repair)
by jal3866 4/29/2012 9:35:59 AM(UTC)
by spearmint 8/14/2010 5:33:01 AM(UTC)
Dryer Humms (Dryer Repair)
by wortmonger 5/28/2010 6:54:32 AM(UTC)
Dryer humming when starting but drum will not turn (Dryer Repair)
by heidi1005 11/2/2009 4:44:07 AM(UTC)
