pdowney
#1 Posted : Wednesday, October 17, 2007 5:15:30 AM(UTC)
pdowney
Will a blown thermal fuse keep the timer from end of cycle?
Pegi
#2 Posted : Wednesday, October 17, 2007 10:01:35 AM(UTC)
Pegi
In a gas dryer yes, if the dryer is not heating the timer will not advance in the auto cycles...that thermofuse would kill the power to the heat circuit in a gas WP dryer, if it is bad check your dryer vent, your dryer overheated for some reason, usually a clogged vent to the outside..
pdowney
#3 Posted : Thursday, October 18, 2007 5:32:54 AM(UTC)
pdowney
yes the dryer will keep running with a blown termal fuse. Timer will not time out. By the prints & timer control this looks like a safety type circut, but i was not sure. Replaced termal fuse and all is well.
P.S. daughter tried to dry 2 loads at 1 time thus the blown fuse.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
by SEMIFAST0 3/15/2015 9:00:11 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
Belarus chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
