rickrowan1202
#1 Posted : Thursday, March 3, 2011 7:18:42 AM(UTC)
rickrowan1202
my dryer does not heat up, the drum turns but the cycle knob is not moving. I check the circuit breaker and the plug is in there is air flow going through the vent.
#2 Posted : Thursday, March 3, 2011 6:32:18 PM(UTC)
Replacement parts for WHIRLPOOL EED4300VQ1 29`` ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Place the unit in timed dry, now does the timer advance.
If not then odds are you have a power problem as this unit's timer gets power directly from the 240 volts in timed dry.
The heater also uses 240.
If it does advance then it could be that the heater is open.
In auto modes the timer motor gets power through the heating coil when the coil is shut off so if the heater burns out the timer will not advance.
No advance in timed dry
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Applianceaid
Video looks good but there are a couple comments on it
1. Do not like to see connectors pulled off by using the wire.
2. Although they do it they do not say to replace the wires on the components before moving onto the next device, otherwise you can end up with a bunch of wires and no idea where they go.
File Attachment(s):
EED4300.pdf (549kb) downloaded 3 time(s).
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Frigidaire model ferb5700ds0 electric dryer (Dryer Repair)
by rnh7133 7/29/2023 6:22:58 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Older Speed Queen electric dryer (Dryer Repair)
by Guest 3/29/2023 5:23:19 AM(UTC)
