water not getting to icemaker but works in door ice maker not making ice
You may have a supply tube blocked with ice, usually where it enters the back of the freezer compartment... Use hair dryer to remove ice; this can be caused by a leaky water supply valve... I'm used to seeing more characters in the model number than you provided... Usually 3 digits followed by a dot then more digits...
Thanks to Tom and your service you saved us a service call!I defrosted water line to icemaker and everything is fine, Thankyou, Ken Stanley
Thank you so much for your help! Water line was frozen and now defrosted and working fine.thamks again, Ken
