rgarippa
#1 Posted : Tuesday, October 16, 2007 8:08:06 AM(UTC)
rgarippa
My Maytag Refrigerator Model # msd2756geb does not go below 45 degrees in the fresh food side. The repairman took a two day recording of the temperature on both the fresh food side and the frozen food side . He now says he can fix the problem by replacing the "Warming Kit". Can you tell me if this sounds right and what a warming kit will do?
My observation if that there is insufficient air flow from the freezer side into the fresh food side even though the refrigerator cooling lever is in the coolest temperature setting.
#2 Posted : Thursday, October 18, 2007 1:58:05 AM(UTC)
Pull out the back freezer panel and see if the coils are frozen over. If ok and only a light frost over all the coils,replace panel and measure the freezer temperature at the back panel and post.
rgarippa
#3 Posted : Thursday, October 18, 2007 7:19:12 AM(UTC)
rgarippa
I have removed the back panel and there is no frost. The freezer temperature is close to "0". It seems unusual that there is little to no air blowing from the freezer side into the fresh refrigerated side.
#4 Posted : Thursday, October 18, 2007 6:52:38 PM(UTC)
Seems like you have a jammed damper door, or one that is blocked with ice, just pull upper fridg. housing apart and check.
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
