wet
#1 Posted : Friday, February 25, 2011 1:14:15 PM(UTC)
wet
I have a question about the high limit thermostat. I have three wires from my dryer, two red and one orange. The new high limit has terminals for the two red and came with a connector wire from the thermostat to the element. What do i do with the extra orange wire?
murderurfriends
#2 Posted : Friday, February 25, 2011 4:28:54 PM(UTC)
murderurfriends
I believe you have to cut the wires and splice together should have come with instructions and new connector as well
#3 Posted : Saturday, February 26, 2011 2:35:06 AM(UTC)
A make and model number may help others help you.
High Limit Thermostat Question (Dryer Repair)
by alawaterdog 10/3/2015 7:25:13 AM(UTC)
High Limit Thermostat (Dryer Repair)
by Eugene Chun 7/23/2015 5:27:36 AM(UTC)
Dryer won't dry replaced, coil, cycling thermostat high limit thermostat (Dryer Repair)
by Replacedeverythingindryer 2/17/2015 2:17:26 PM(UTC)
How To Reset High Limit Thermostat (Dryer Repair)
by scubes 7/21/2014 4:06:28 PM(UTC)
Roper dryer keeps blowing high limit thermostat (Dryer Repair)
by Sparty1721 11/17/2013 8:42:25 AM(UTC)
High Limit Thermostat wire burned (Dishwasher Repair)
by rosskell 11/9/2013 6:49:47 AM(UTC)
Wire connecting heating element and high limit thermostat burned (Dryer Repair)
by stubarnes4prez 9/27/2013 2:55:24 PM(UTC)
Location of high limit thermostat (Dishwasher Repair)
by vinniev 2/18/2013 4:27:09 PM(UTC)
using high limit thermostat in place of thermal cutoff (Dryer Repair)
by deerichards 5/9/2012 12:41:24 PM(UTC)
Wire connection to high limit thermostat (Dryer Repair)
by ctweedy 5/7/2012 2:23:52 PM(UTC)
High Limit thermostate (Dryer Repair)
by dsocha 1/10/2012 5:54:59 PM(UTC)
Dryer -High Limit Thermostat issue (Dryer Repair)
by drj46189 7/4/2011 5:49:09 PM(UTC)
Replace high limit thermostat a or cycling thermostat along with the thermal fuse? (Dryer Repair)
by BrassMonkey 6/17/2010 12:35:31 AM(UTC)
by davewild 4/20/2010 7:03:18 PM(UTC)
how do I test the high limit thermostat (Oven Repair (including Ranges and Cooktops))
by naudnice 12/20/2008 8:02:13 AM(UTC)
