Whirlpool dryer starts, igniter comes on, then burner comes on for about 15-25 seconds.. Burner shuts off but motor continues to run till I hit stop It will not immediately relite but will restart After a few mintues I can restart and it relites but then shuts down in the same fashion after about 15-25 seconds
I have replaced gas valve coils I have checked continuity of the thermal switches and all are short circuit. I have not checked them while the unit is running. Can they open then reclose?
I have cleaned all vents I have run with the dryer vent disconnected from the wall just to be sure I have also cleaned the fan housing
any thoughts welcome
How does the flame look? If it looks fine it most likely is a weak high limit tripping prematurely
