thecatfan1
#1 Posted : Wednesday, February 23, 2011 5:45:39 PM(UTC)
thecatfan1
Whirlpool dryer starts, igniter comes on, then burner comes on for about 15-25 seconds..
Burner shuts off but motor continues to run till I hit stop
It will not immediately relite but will restart
After a few mintues I can restart and it relites but then shuts down in the same fashion after about 15-25 seconds
I have replaced gas valve coils
I have checked continuity of the thermal switches and all are short circuit. I have not checked them while the unit is running. Can they open then reclose?
I have cleaned all vents
I have run with the dryer vent disconnected from the wall just to be sure
I have also cleaned the fan housing
any thoughts welcome
murderurfriends
#2 Posted : Friday, February 25, 2011 3:37:13 PM(UTC)
murderurfriends
How does the flame look? If it looks fine it most likely is a weak high limit tripping prematurely
