Refirgerator works fine for 5-7 days, then gets too warm. Unplugging the unit for 1 minute resets everything and it works fine for another week or so. Thermistor values check out ok, 8 ohms for about 50 degrees.
This has happened 4 times now
I suspect the defroster circuit is sticking on. Is the defroster time built into the control board and how do check it out before ordering parts?
thanks
Originally Posted by: stan denoo  ...Refirgerator works fine for 5-7 days, then gets too warm... We need as much information as possible. Gene.
