rmg61
#1 Posted : Friday, February 18, 2011 10:02:34 AM(UTC)
rmg61
How Do I Replace The Heating Element?
Jeff / APP Team
#2 Posted : Friday, February 18, 2011 10:21:37 AM(UTC)
Jeff / APP Team
Rank:: Advanced Member
First disconnect the power to the unit. You will need to do this repair from under the bottom of the dishwasher. Remove the toe panel and look where the ends of the heater comes out of the tub. There will be a wire on each end. Unplug the wires. Next you will see a big plastic nut on each end of the heater. Remove the nut from the heater. There will be a washer on top and bottom of the heater. Lift the ends of the heater out of the tub and slide the heater out of the brackets. Reinstall is the reverse of the above. Here is a link to the parts diagram to help you.
Heater parts replacement parts for WHIRLPOOL KUDM01TJBL1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Dishwasher not heating after replacing Heating element and thermostat (Dishwasher Repair)
by smbegg 1/4/2016 11:47:09 AM(UTC)
replacing heating element (Dryer Repair)
by Deana2015 8/26/2015 5:06:01 PM(UTC)
Replacing heating element (Oven Repair (including Ranges and Cooktops))
by Allen5391 8/27/2014 5:30:50 PM(UTC)
Replacing Heating Element on Americana Dishwasher (Dishwasher Repair)
by bryanc1 9/26/2012 7:49:40 PM(UTC)
Replacing heating element GE dryer (Dryer Repair)
by nfntjy 2/18/2011 12:05:29 PM(UTC)
Replacing Heating Element (Dryer Repair)
by Billybv 11/20/2010 8:32:37 AM(UTC)
No Heat after replacing Heating element (Dryer Repair)
by renttibw 6/16/2010 9:25:17 AM(UTC)
Replacing heating element (Dryer Repair)
by fragousa 4/17/2010 4:07:40 PM(UTC)
Replacing heating element in Kenmore stacked dryer (Dryer Repair)
by LLesniak 2/2/2010 12:27:57 PM(UTC)
oven wont heat after replacing heating element (Oven Repair (including Ranges and Cooktops))
by jeffrey l 12/4/2009 5:27:23 PM(UTC)
by jeffrey l 12/4/2009 5:26:47 PM(UTC)
Replacing heating element on Whirlpool dryer (Dryer Repair)
by GEEMAN 11/8/2009 3:20:44 PM(UTC)
Replacing heating element (Dishwasher Repair)
by jose1 7/6/2009 10:32:36 AM(UTC)
by acecando 6/9/2009 3:17:46 PM(UTC)
After replacing heating element it blew a fuse (Dishwasher Repair)
by Sst0214 5/5/2009 8:14:52 AM(UTC)
