renttibw
#1 Posted : Wednesday, June 16, 2010 9:25:17 AM(UTC)
renttibw
Had no heat replaced heating element still no heat. Please outline steps and settings on a digital multimeter to check other components. What reading should I be getting across the heating element? Laundry is piling up! Thanks renttibw
#2 Posted : Thursday, June 17, 2010 2:14:13 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406681.pdf
[COLOR="Blue"]Please outline steps and settings on a digital multimeter to check other components. [/COLOR]
Other components (fuses and thermostats) all should be 0 ohms.
Note: That you cycling (control) thermostat will have 4 connections.
2 for the contacts should be 0 ohms
2 for it's internal heater should be 7,000 ohms approximately.
Also when checking for ohms I always short the meter leads together to see where true 0 is re: is the meter giving an offset..
[COLOR="Blue"]What reading should I be getting across the heating element?[/COLOR]
Should be approximately 10 ohms.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
[COLOR="Red"]Be careful 240 volts is lethal.[/COLOR]
