cyndig
#1 Posted : Tuesday, February 15, 2011 3:20:42 PM(UTC)
cyndig
There is no water coming into my dishwasher. The water and power is hooked up right. I can turn it on and I can hear the motor working but when I look inside its bone dry.
#2 Posted : Wednesday, February 16, 2011 1:17:08 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for mdb9750aw models | AppliancePartsPros.com
You have 3 devices in the water valve circuit,
The control board', the water valve and the float (overflow) switch
Take the kick panel off and check the overflow switch. It should be activated. If not there may be crud in the float assembly which is holding the float up.
The rest of the checking is easiest with a meter.
Check for 120 volts across the water valve when it should be on.
If you have 120 volts then there is a problem with the valve.
Could be the valve is toast.
Could be that the screen filter built into the input side of the valve is clogged.
Remove the valve from the machine and check/clean the screen filter.
Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
If there is no voltage.
Check for voltage across the valve and float switch combination.
If there is voltage, then double check by measuring across the float switch.
If there is voltage there then the float switch is toast.
If there is no voltage across the valve and float switch combination, then either you have a broken wire from the the control board, a bag connector or the control board is toast.
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 7/28/2022 3:00:04 PM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
please help kitchen aid fridge noise (Refrigerator & Freezer Repair)
by marcelmcesar 8/3/2021 4:54:39 PM(UTC)
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
by swingbyte 4/1/2021 11:35:24 PM(UTC)
Fisher & Paykel DEIX2 Dryer Keeps tripping t-stat Please Help (Dryer Repair)
by hotlicksexhaust 5/7/2020 8:22:39 AM(UTC)
Silence is definitely not Golden (LG) ... Please help (Microwave Repair)
by benh1234 1/16/2019 2:13:22 PM(UTC)
Please Help - Whirlpool WFG524SLAS (Oven Repair (including Ranges and Cooktops))
by yozzomp 12/5/2018 1:27:04 PM(UTC)
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 3/23/2018 2:24:04 PM(UTC)
Mystery part loose in box - please help identify! (Refrigerator & Freezer Repair)
by xkandakex 12/14/2017 10:36:27 AM(UTC)
PLEASE HELP! Quiet Partner III Cancel, Rinse Only Lights Blinking (Dishwasher Repair)
by zed40 3/24/2017 6:16:49 PM(UTC)
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 2/11/2017 8:02:28 AM(UTC)
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 2/5/2017 8:12:19 AM(UTC)
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Please help with my GE replacement motor wiring (Dryer Repair)
by Mjutton 6/29/2016 7:36:12 PM(UTC)
