FDAR
#1 Posted : Friday, December 12, 2008 4:45:01 PM(UTC)
FDAR
I am working on a Whirlpool gas dryer and unable to figure out why there is no flame. Igniter comes on, thermostat clicks and a very small flame (about 1'') can be seen at the beginning of the tube, not the end by the igniter. I have replaced the coils and thermostats, but no change. Any help would be greatly appreciated as I am not sure if it is the valve or if there is a test to check the valve. Thank you for you expert advice as always.
FDAR
#2 Posted : Thursday, December 18, 2008 7:03:10 PM(UTC)
FDAR
Any help would be appreciated......
libertyappl
#3 Posted : Thursday, December 18, 2008 7:44:58 PM(UTC)
libertyappl
Ohm out the ignitor, should be around 3 to 3.5 ohms. If it ohms out ok, the valve probably needs replaced.
Nat
#4 Posted : Sunday, December 21, 2008 2:20:19 AM(UTC)
Seems like your gas valve is bad, or the gas pressure to it is low. For safety reasons, I would get a pro to look at it.
FDAR
#5 Posted : Monday, December 22, 2008 7:14:30 PM(UTC)
FDAR
I replaced the valve assembly (with new coils) and now have a good flame, but it only last about 20 seconds then goes off for approximately 1-1/2 minutes and comes back on for about 20 more seconds. I also hear what seems to be an electrical noise I think prior to the flame going out, checked all connections and everything is tight.
libertyappl
#6 Posted : Tuesday, December 23, 2008 5:39:55 AM(UTC)
libertyappl
As richappy said it may be time to call a tech.
Nat
No flame LG dlg2532w (Dryer Repair)
by Rick Sutton 3/5/2022 5:40:18 PM(UTC)
Ignitor sparks and gas is flowing but no flame (Oven Repair (including Ranges and Cooktops))
by jimb39 11/18/2018 1:01:33 PM(UTC)
Dryer Ignitor Glows but no Flames (Dryer Repair)
by ken1234ken 7/9/2016 12:05:48 PM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
Igniter Glows, No Flame - replaced gas coil and thermal cuttoff (Dryer Repair)
by knnguyen86 10/24/2014 9:46:08 PM(UTC)
Dryer has no flame (or heat) (Dryer Repair)
by MrChip 1/14/2014 12:22:21 PM(UTC)
no flame (Dryer Repair)
by dong 7/30/2013 12:31:34 AM(UTC)
Kenmore Dryer - Ignitor glows for 10 seconds no flame (Dryer Repair)
by jwmark 12/12/2012 7:59:10 PM(UTC)
Kenmore Dryer starts. No Ignitor, No flame no heat (Dryer Repair)
by jmrec100 12/11/2012 9:14:50 PM(UTC)
by joe5427 9/17/2012 4:25:49 PM(UTC)
Whirlpool heats for a minute and then no flame (Dryer Repair)
by karolpl2004 7/13/2012 12:51:48 PM(UTC)
Gas Dryer no flame (Dryer Repair)
by Emazing 6/6/2012 1:57:26 PM(UTC)
gas dryer no flame (Dryer Repair)
by stargate1 6/12/2011 11:47:06 AM(UTC)
Igniter lights but no flame (Dryer Repair)
by recap 6/3/2011 2:40:19 PM(UTC)
Magic Chef oven does not turn on - no flame (Oven Repair (including Ranges and Cooktops))
by teapa 5/20/2011 7:42:07 AM(UTC)
