Danninbill
#1 Posted : Thursday, February 10, 2011 7:22:28 AM(UTC)
Danninbill
My Whirlpool double wall oven # RBD275PDB14 control panel doesn't show any error codes but will not function, there are no lights, no clock, and the oven's will not opperate. If you push the clock button you will get 2 short beeps followed by 3 short beeps. After reading alot of these posts it seems logical that it is proably the control unit. My question is that this control panel also comes with a small sister board, what is this for? and how can I be sure that the control panel is truely the problem. according to your parts list, as well as Whirlpool's they no longer manufacture this panel and have no replacements, WHY? Next question: After reading all these forum questions and answers on whirlpool oven problems, why hasn't there been a consumer recall on their control panels.
#2 Posted : Friday, February 11, 2011 6:17:46 AM(UTC)
Replacement parts for WHIRLPOOL RBD275PDB14 27`` BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com
Since the control does beep I would say that it's power supply fuse is OK.
Could be a problem with the power transformer. The tech sheet gives the winding resistances. Be sure to also check between the windings and the case just to make sure a winding has not shorted out internally to each other or the case.
Unfortunately I do not know what voltage the transformer should put out.
Perhaps someone else will jump in who does.
[COLOR="DarkRed"]
My question is that this control panel also comes with a small sister board, what is this for?[/COLOR]
Part of the latch system, see the tech sheet.
[COLOR="DarkRed"]how can I be sure that the control panel is truely the problem. according to your parts list,[/COLOR]
All you can do is eliminate other cause, if everything else looks OK then all that is left is the control board. No manufacturer publishes board schematics so you cannot troubleshoot the board itself.
[COLOR="DarkRed"]as well as Whirlpool's they no longer manufacture this panel and have no replacements, WHY?[/COLOR]
You would have to ask Whirlpool why the board is obsolete.
There are companies out there that will repair blown timers/control boards.
Just Google " appliance timer repair"
[COLOR="DarkRed"]Next question: After reading all these forum questions and answers on whirlpool oven problems, why hasn't there been a consumer recall on their control panels.[/COLOR]
Just about all parts fail eventually and unless it is a very, very common problem and there is a customer uproar or it is a safety issue you will not see a recall.
File Attachment(s):
RBD275.pdf (518kb) downloaded 19 time(s).
Whirlpool double oven failure (Oven Repair (including Ranges and Cooktops))
by pszopiak 3/3/2013 3:40:22 PM(UTC)
oven failure code (Oven Repair (including Ranges and Cooktops))
by hawk65 3/12/2012 6:10:44 AM(UTC)
Electric oven failure after self clean cycle (Oven Repair (including Ranges and Cooktops))
by todrini 12/27/2010 7:06:21 AM(UTC)
Post cleaning oven failure (Oven Repair (including Ranges and Cooktops))
by malthound 10/28/2010 6:08:33 PM(UTC)
Whirlpool Oven Failure after Power Fail (Oven Repair (including Ranges and Cooktops))
by cweaker 5/14/2010 7:55:01 AM(UTC)
dacor oven failure (Oven Repair (including Ranges and Cooktops))
by cfilice 5/10/2008 8:00:00 AM(UTC)
F 1 oven failure code (Oven Repair (including Ranges and Cooktops))
by fish 5/5/2008 7:24:41 AM(UTC)
Dacor double oven, lower oven failure (Oven Repair (including Ranges and Cooktops))
by tuckspub 4/22/2008 7:19:19 AM(UTC)
Oven Failure (Oven Repair (including Ranges and Cooktops))
by rcapaldo 2/19/2008 1:09:38 PM(UTC)
Oven failure F1 after self cleaning (Oven Repair (including Ranges and Cooktops))
by Jeremy 11/29/2007 9:21:32 PM(UTC)
