jmeza949
#1 Posted : Wednesday, December 10, 2008 6:20:11 PM(UTC)
jmeza949
This morning when we first started the first drying load of cloth, the dryer
didn't want to start.
jmeza949
#2 Posted : Wednesday, December 10, 2008 6:39:41 PM(UTC)
jmeza949
my electric dryer does not want to start
#3 Posted : Thursday, December 11, 2008 3:13:34 AM(UTC)
Here is your parts breakdown
Model TEDX640EQ1
Here is a tech sheet (wiring diagram) This is for an EQO, could not find EQ1. Should be close.
https://www.servicematters.com/d...0Sheet%20-%203401728.pdf
First flip your breaker off/on slowly a couple times. Sometimes half the line can drop out without tripping the breaker.
Do you have a meter?
Next would be the thermal fuse.
I believe it is Item 23 in Section 3
If you do not have a meter, you can short the two wires together, tape them up to ensure they do not short to the frame and give it a try.
If it runs, order and replace the fuse. Do not run the unit unattended with the short. This is a fire safety device!!!
Make sure to unplug the machine before working on it.
240 Volts KILLS!!!
The most common cause of this fuse blowing is low air flow so if it is the fuse clean and check your vent system.
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Frigidaire model ferb5700ds0 electric dryer (Dryer Repair)
by rnh7133 7/29/2023 6:22:58 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Older Speed Queen electric dryer (Dryer Repair)
by Guest 3/29/2023 5:23:19 AM(UTC)
