Originally Posted by: dcommon  There is a hairline crack in the lower left corner of my cooktop. Is it necessary to replace the entire cooktop or is there another alternative? If a replacement is necessary can my husband do it? Where could we get instructions for replacing the cooktop? Thanks for your help. D, Sorry, but there are no other safe alternatives, For safety sake , you should replace the cooktop assembly(it's all one piece). The glas portion of the cooktop, is a heat resistant temperred safety glass, and there is a possibility of it shatterring, and caving in, when your cooking,and creating more damage to the range and yourself. It's an expensive part, but a somewhat easy repair. Part number: AP4482718
Here are some general, basic instructions from the service manual, Remember to label and mark any wires or components you remove or disconnect. REMOVING AN ELEMENT & LIMITER AND THE COOKTOP GLASS ASSEMBLY CAUTION:
When you work on the electric range, be careful when handling the sheet metal parts. Sharp edges may be present, and you can cut yourself if you are not careful. WARNING 1. Turn off the electrical supply going to the range. 2. Open the oven door. 3. Remove the two cooktop bracket screws from the bottom front of the cooktop. 4. Pull the cooktop forward far enough to unhook it from the top of the range. 5. Lift the front of the cooktop and rest it against the control panel. CAUTION: Be careful that the cooktop does not accidentally fall forward. 6. To remove an element and limiter: a) Remove the wires from the element and limiter terminals. b) Remove the element bracket screw (shown above) for the element and limiter you are servicing. c) If you are removing the center element and limiter, remove the screw from the hot surface indicator bracket and remove the indicator. d) Carefully lift the bottom of the bracket just far enough to remove the element. NOTE: If you are removing an element at the top of the bracket, remove the lower element first, lay it on top of the range, and then remove the top element from the bracket. e) Remove the screws from the limiter and remove it from the element. NOTE: Be careful when you remove the limiter that you do not break the sensor tube.REASSEMBLY NOTE: When you reinstall the element and limiter, make sure that the alignment pins are inserted into the correct bracket slots, (see the photo to the right) then reinstall the bracket screw to secure it to the cooktop.7. To remove the cooktop glass assembly: a) Remove the two screws from the hot surface indicator assembly bracket and remove the assembly from the frame. b) Carefully lift the bottom of the left bracket just far enough to remove the bottom element, then repeat the procedure for the bottom right and center elements. Lay each of the elements on top of the range. c) Lift the brackets and remove the top two elements and lay them on top of the range. d) Lift the element brackets and unhook them from the top of the cooktop. e) Remove the old cooktop glass assembly from the range.REASSEMBLY NOTE: When reinstalling the elements in the new cooktop glass assembly, make sure that the alignment pins are in their correct bracket slots.:) :) :)
