Dryer Wont heat and lot of water in dryer. it also sqeaks. i think it may be heater element?
Originally Posted by: BCMS69C  Dryer Wont heat and lot of water in dryer. it also sqeaks. i think it may be heater element? BCMS, First, There should be no water in the dryer drum, combined with a no heat complaint, My first guess would be that you have a clogged or kinked exhaust vent, the moisture in the clothes, is not venting out and the condensation is accumulating in the drum. Disconnect the exhaust vent, clear any debris in the dryer exhaust, and check the dryer for heat. If it heats, you'll need to check and clean the remainder of the exhaust vent system, and check the vent hood(outside)for damage or clogs. As for the squeak noise, there are Two drum rollers mounted on the rear bulkhead(wall of the dryer drum) Part number: AP3098345
An idler pulley, mounted to the base of the unit near the motor assembly Part number: AP2911909
Or something stuck in the drum seal(s) around the front/rear of the tumbler. You will need to dismantle the unit to access these components properly, Let's see what happens once you check the venting and the heat problem, and see if you can isolate the area where the noise is located ,then we can get you the "teardown" info and get the noise taken care of. :) :) :)
