What would be the problem if the dryer squeaks when it turns with clothes in it? I look inside the dryer, the small side of pulley idler was chewed up by the belt, and the belt keeps sliding off and now the belt broke:rolleyes: ..
Originally Posted by: Deraldine  What would be the problem if the dryer squeaks when it turns with clothes in it? I look inside the dryer, the small side of pulley idler was chewed up by the belt, and the belt keeps sliding off and now the belt broke:rolleyes: .. Deraldine, That could have also been the squeak noise, Have you replaced the belt and idler pulley, yet ? Part number: AP4324040
Part number: AP2043227
There are other possibilities, Something stuck in the felt seal on the front tumbler support, worn out drum slides, also on the front tumbler support. and a noisy tumbler drum shaft and bearing assembly, you'll need to remove the tumbler to check that, you need to lift up on the tumbler and pull out on the tumbler at the same time, to unlock the shaft from the bearing assembly in the back of the cabinet assembly. :) :) :)
