Deraldine
#1 Posted : Sunday, February 6, 2011 7:03:48 PM(UTC)
Deraldine
What would be the problem if the dryer squeaks when it turns with clothes in it? I look inside the dryer, the small side of pulley idler was chewed up by the belt, and the belt keeps sliding off and now the belt broke:rolleyes: ..
Joe / APP Team
#2 Posted : Monday, February 7, 2011 1:36:14 PM(UTC)
Joe / APP Team
Deraldine,
That could have also been the squeak noise,
Have you replaced the belt and idler pulley, yet ?
Part number: AP4324040
Part number: AP2043227
There are other possibilities,
Something stuck in the felt seal on the front tumbler support, worn out drum slides, also on the front tumbler support.
and a noisy tumbler drum shaft and bearing assembly, you'll need to remove the tumbler to check that, you need to lift up on the tumbler and pull out on the tumbler at the same time, to unlock the shaft from the bearing assembly in the back of the cabinet assembly.
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Dryer squeaks when drum is turning (Dryer Repair)
by Rubenl 10/22/2014 4:14:28 PM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
Dryer squeaks loudly after heating up. (Dryer Repair)
by hogman143 6/11/2012 10:50:15 AM(UTC)
GE Dryer Squeaks while running (Dryer Repair)
by slinky75 4/12/2012 11:15:40 AM(UTC)
Admiral dryer squeaks and makes noise (Dryer Repair)
by lormike 3/21/2012 11:26:10 AM(UTC)
dryer squeaks loudly (Dryer Repair)
by bur831 11/4/2010 2:37:26 PM(UTC)
dryer squeaks (Dryer Repair)
by fipp 5/30/2010 7:42:26 AM(UTC)
by denjean 4/18/2010 6:29:44 PM(UTC)
dryer squeaks and rumbles (Dryer Repair)
by jimmy6571@sbcglobal.net 3/9/2010 2:01:32 PM(UTC)
Dryer squeaks (Dryer Repair)
by robertson5 3/8/2010 6:36:51 AM(UTC)
Dryer squeaks/squeals (Dryer Repair)
by Skuter7199 1/25/2010 4:08:13 PM(UTC)
Dryer Squeaks Loudly (Dryer Repair)
by Tidalflats 12/1/2009 1:49:53 PM(UTC)
Dryer squeaks real loud (Dryer Repair)
by Sheebee 9/28/2009 7:48:09 AM(UTC)
