Galan of PT
#1 Posted : Monday, December 8, 2008 3:16:12 PM(UTC)
Galan of PT
Door gasket has deteriorated at bottom right side of door. Unit leaks.
How do I remove and replace gasket?
What is reliable source for the part?
I a repair manual available?
#2 Posted : Monday, December 8, 2008 5:59:25 PM(UTC)
Just pull the old gasket out and push the new one in. You can use a little of a dish soap as a lubricant for the new gasket installation. Provide an extra 1" to 11/4" on each side to cover the bottom of the tank (for a dam to prevent leaking from splashing at the bottom corners of the tank).
- The part number for the door gasket is AP2802352
Here are the break down diagrams for the Bosch dishwasher Model SHU5306 UC/12 (FD 8003-)
Dishwasher Door Gasket swells and leaks (Dishwasher Repair)
by Disgusted 1/4/2012 11:30:44 AM(UTC)
Dishwasher Door Gasket Kit AP3672571 problems (Dishwasher Repair)
by KeithD 6/23/2009 1:48:09 AM(UTC)
Replacement of Dishwasher door gasket (Dishwasher Repair)
by vaiaar 5/3/2009 4:26:43 PM(UTC)
by Bill Wood 3/28/2009 12:24:37 PM(UTC)
