shugdalele
#1 Posted : Friday, February 4, 2011 8:25:38 AM(UTC)
shugdalele
My kenmore washer goes through the wash cycle normal but when it gets to the spin cycle, it won't spin. It drains the water but doesn't start spinning. If I open and close the lid, then it will spin and finish the cycle. Am I looking at a problem with the neutral drain assembly?
#2 Posted : Friday, February 4, 2011 4:39:40 PM(UTC)
Yes, this washer has a neutral drain transmission which should pause for a few seconds during the drain to engage the spin. The correction is to replace the timer.
- The timer Part number: AP3131136
Kenmore 80 Series won't spin - no motor sound (Washer Repair)
by mkdwns 9/8/2015 4:57:50 PM(UTC)
Kenmore 80 series won't spin (Washer Repair)
by RileyHereford 5/24/2014 4:09:05 PM(UTC)
Kenmore 80 Series won't spin (Washer Repair)
by Kristine 7/28/2010 9:11:31 PM(UTC)
Kenmore 80 Series won't spin or agitate (Washer Repair)
by Mirage_Man 7/11/2010 11:49:12 AM(UTC)
by Mike Ganoe 5/17/2009 7:23:49 AM(UTC)
