chris mac
#1 Posted : Thursday, February 3, 2011 6:11:59 PM(UTC)
chris mac
i have a kenmore dryer that just will not heat i have checked continuity with a multimeter from the heating elements all are coming up with great continuity the only one that's not is the thermister this goes about half way on my multimeter so i bought a new one and the new one is doing the same thing so im guessing this is not the problem . i took out the thermostat to clean it i shook it and it made a rattling noise could this be the problem?i have also checked the outlet and theres 240vs coming in so no problems there . someone please help im racking my brains but cant come up with anything
RoboJoe Industries
#2 Posted : Thursday, February 3, 2011 8:08:46 PM(UTC)
RoboJoe Industries
Check continuety through the thermal fuses.
One looks like a little white plastic bullet. The other is on the heater housing and looks like a little R2D2.
Could also be a wire burnt off the pigtail terminal block.
http://www.upthemileage.com
http://www.appliancerepair-shiawassee.com
#3 Posted : Friday, February 4, 2011 12:40:37 AM(UTC)
[COLOR="DarkRed"]the only one that's not is the thermister this goes about half way on my multimeter[/COLOR]
The thermistor should read about 12,000 ohms at room temperature
[COLOR="DarkRed"]i took out the thermostat to clean it i shook it and it made a rattling noise could this be the problem?[/COLOR]
Yes it could, it should not rattle. I am assuming you are talking about the hi-limit thermostat (tenth item in the parts listing).
Could be it just blew but also could be that it was switching on/off when it blew. It should only switch off/on if you have a problem elsewhere in the unit as it is a safety device with the thermal cut-off (first item in the parts listing) as a back up.
Pull the heater relay and check that the contacts are open (common to normally open) (the two large red wires), could be the contacts are welded together.
When/if you get it all back together and have heat run a low temperature cycle to make sure the the unit is giving low heat. If not then you still have a problem.
[COLOR="DarkRed"]i have also checked the outlet and theres 240vs coming in so no problems there .[/COLOR]
As RoboJoe said check the terminal strip voltage it could be a burned off wire or a bad line cord.
You have checked L1 to L2 for 240 volts at the plug.
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
At the top of my list would be your rattling hi-limit thermostat.
Also check that the thermal cut-off is OK (0 ohms).
chris mac
#4 Posted : Sunday, February 6, 2011 6:58:57 PM(UTC)
chris mac
it was the heater relay i switched it with the motor relay just to be sure and it started to heat. part is on its way much appreciated guys
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
