robin lala
#1 Posted : Wednesday, January 26, 2011 2:43:29 PM(UTC)
robin lala
the unit has power (lock light is on). when I try to run a cycle it does nothing. The locked light blinkes once each time i hit the wash buttons. Is there a way to reset?
#2 Posted : Wednesday, January 26, 2011 3:29:08 PM(UTC)
Quote:
OK all you need to do is hold the "Air dry" button down for the count of 5 and the "Locked" light should go off.
Read more: http://forum.appliancepartspros...ked-4.html#ixzz1CBu1X6oJ
http://forum.appliancepartspros.com
masterappliancetech
#3 Posted : Wednesday, January 26, 2011 7:53:18 PM(UTC)
masterappliancetech
Thats right if the lock light dose not turn off you might need to replace the control panel. Somtimes they will fail and cause this problem.
Aurora Appliance Repair
