the unit has power (lock light is on). when I try to run a cycle it does nothing. The locked light blinkes once each time i hit the wash buttons. Is there a way to reset?
Thats right if the lock light dose not turn off you might need to replace the control panel. Somtimes they will fail and cause this problem. Aurora Appliance Repair
