AppliancePartsPros.com
Appliance Repair Help
Washer Repair
kenmore front load washer very slow spin cycle won,t extract water
my front load washer spins very slow and will not extract the water could this be the spin control board if not what should i check THANKS FOR ANY INFO RANDYB.2:eek:
Does the spin basket swish around at a "normal" speed" during wash cycle?
Hi Check the coin trap. Mine did the same thing and I took the hose to the pump off and found all sorts of stuff clogging it and keeping it from draining. The slow spin is a safety measure in case this becomes clogged. hope this helps
Take the bottom panel off the front, and once you do, you will see the pump right in front. Unscrew the front of it, and pull all the stuff out. Unplug the washer before you do this, and I would lean it back up against the wall, so when you unscrew the pump cover the water won't come out all over you. Tom ApplianceEducator.com
Thanks For The Help I Really Appreiate It.randyb.2
Originally Posted by: kenny21  Hi Check the coin trap. Mine did the same thing and I took the hose to the pump off and found all sorts of stuff clogging it and keeping it from draining. The slow spin is a safety measure in case this becomes clogged. hope this helps Thanks for the information, I just did this and found $2.25 in coins. Now we are back in business, let wash day progress.:) A happy lady!
Washer Repair
