randyb.2
#1 Posted : Wednesday, December 3, 2008 1:30:59 PM(UTC)
randyb.2
my front load washer spins very slow and will not extract the water could this be the spin control board if not what should i check THANKS FOR ANY INFO RANDYB.2:eek:
#2 Posted : Wednesday, December 3, 2008 2:14:55 PM(UTC)
Does the spin basket swish around at a "normal" speed" during wash cycle?
kenny21
#3 Posted : Wednesday, December 3, 2008 2:39:33 PM(UTC)
kenny21
Hi
Check the coin trap. Mine did the same thing and I took the hose to the pump off and found all sorts of stuff clogging it and keeping it from draining. The slow spin is a safety measure in case this becomes clogged.
hope this helps
kayakcrzy
#4 Posted : Thursday, December 4, 2008 5:05:29 AM(UTC)
kayakcrzy
Take the bottom panel off the front, and once you do, you will see the pump right in front. Unscrew the front of it, and pull all the stuff out. Unplug the washer before you do this, and I would lean it back up against the wall, so when you unscrew the pump cover the water won't come out all over you. Tom ApplianceEducator.com
randyb.2
#5 Posted : Sunday, December 7, 2008 3:25:18 PM(UTC)
randyb.2
Thanks For The Help I Really Appreiate It.randyb.2
jpope123
#6 Posted : Sunday, November 7, 2010 2:07:08 PM(UTC)
jpope123
Originally Posted by: kenny21 Go to Quoted Post
Hi
hope this helps
Thanks for the information, I just did this and found $2.25 in coins. Now we are back in business, let wash day progress.:) A happy lady!
