Temperture control problem. when I set temp to 350 the oven begins to heat. After approximatlely 10 min indicator sounds that temp has been reached. On checking the oven temp I found the temp is 100 degrees lower than what it should be. I have to move the temp setting up to 450 for it to reach the temp I need. This sometimes takes 30 or more minets. I need check out procedures to check oven sensor or control panel also procedure to open up control panet. Please reply thanks
Originally Posted by: bgarrett6  Temperture control problem. when I set temp to 350 the oven begins to heat. After approximatlely 10 min indicator sounds that temp has been reached. On checking the oven temp I found the temp is 100 degrees lower than what it should be. I have to move the temp setting up to 450 for it to reach the temp I need. This sometimes takes 30 or more minets. I need check out procedures to check oven sensor or control panel also procedure to open up control panet. Please reply thanks This is a duplicate post
