bgarrett6
#1 Posted : Friday, January 21, 2011 4:59:04 PM(UTC)
bgarrett6
Temperture control problem. when I set temp to 350 the oven begins to heat. After approximatlely 10 min indicator sounds that temp has been reached. On checking the oven temp I found the temp is 100 degrees lower than what it should be. I have to move the temp setting up to 450 for it to reach the temp I need. This sometimes takes 30 or more minets. I need check out procedures to check oven sensor or control panel also procedure to open up control panet. Please reply thanks
Joe / APP Team
#2 Posted : Wednesday, January 26, 2011 1:46:28 PM(UTC)
Joe / APP Team
This is a duplicate post
Frigidaire range oven problem... (Oven Repair (including Ranges and Cooktops))
by Cr00zng 4/22/2013 7:58:08 AM(UTC)
