Hi Gene,
I've received the igniter but our original one has 2 separate connecters with like the image above but the new one I've just received has a single connecter for both wires. Can we replace them with separate connecters?
Yes. You can cut off the plug and connect the igniter using a high temperature porcelain wire nuts Part number: AP3440631
It sounds a bit strange why the igniter you received, if ordered it from Appliance Parts Pros and the part number is AP2832933, looks different. I'll forward this information to their customer service. Gene.
Originally Posted by: Gene  You are welcome. Keep us posted.
Gene. Gene - how do you install this part? Do you have to take off the kick panel as well as the panel that holds the electrical wires to reach the screws to take off the old ignitor? Thanks much! I have the same issue and just ordered my ignitor.
The installation instructions are attached to the reply. Gene.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi! Just wondering if changing the igniter worked ok??
