machine ran during night. but when we were to unload was still running with display flashing error and will not cancel. it seems to be running but i cannot tell whether it trying to pump water out or in. nothe is happening inside. dishes were clean.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Tried that did not work. Looks as though cycles until drain pump the stuck. I checked switch at over flow it ok. what next?
Can you run the water/test (diagnostics). It may give a clue as to what is going on. |
Originally Posted by: denman  Can you run the water/test (diagnostics). It may give a clue as to what is going on. it let me run one earlier but know it will not. have been able to run rinse cycle but seems to run several cycles but sticks ti the 19 minutes shown. on the other cycles it runs for a while then gets the er code and stops. where as before it let the drain pump keep running.
