Ray Richardson
#1 Posted : Thursday, January 13, 2011 5:14:14 AM(UTC)
Ray Richardson
machine ran during night. but when we were to unload was still running with display flashing error and will not cancel. it seems to be running but i cannot tell whether it trying to pump water out or in. nothe is happening inside. dishes were clean.
#2 Posted : Friday, January 14, 2011 2:44:47 AM(UTC)
Replacement parts for FRIGIDAIRE PLD4375RFC0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf
You did not say what the error was but the tech sheet does give the error codes.
Try unplugging/remove power from the un it for 5 minutes or so to see if it will reset.
Ray Richardson
#3 Posted : Friday, January 14, 2011 11:12:10 AM(UTC)
Ray Richardson
Originally Posted by: denman Go to Quoted Post
http://manuals.frigidaire.com/p.../Kinston/154580201en.pdf
Tried that did not work. Looks as though cycles until drain pump the stuck. I checked switch at over flow it ok. what next?
#4 Posted : Saturday, January 15, 2011 5:47:32 AM(UTC)
Can you run the water/test (diagnostics).
It may give a clue as to what is going on.
Ray Richardson
#5 Posted : Saturday, January 15, 2011 8:54:36 AM(UTC)
Ray Richardson
it let me run one earlier but know it will not. have been able to run rinse cycle but seems to run several cycles but sticks ti the 19 minutes shown. on the other cycles it runs for a while then gets the er code and stops. where as before it let the drain pump keep running.
