I have 2 prophane dryers that wont start the motors just hums.
Could find no info using the given Model Number.
Sounds like both units need new motors.
Try turning the drum by hand, it should turn relatively easy.
Open the door, hold the door switch closed, push the start button, rotate the drum in the correct direction. If it starts up you probably need a new motor.
Watch your knuckles just in case it does start rotating. |
THIS FORUM IS DEAD!!!!!!! |
