mr
Timothy
#1 Posted : Friday, November 28, 2008 3:43:41 PM(UTC)
Timothy
I have 2 prophane dryers that wont start the motors just hums.
#2 Posted : Saturday, November 29, 2008 2:24:28 AM(UTC)
Could find no info using the given Model Number.
Sounds like both units need new motors.
Try turning the drum by hand, it should turn relatively easy.
Open the door, hold the door switch closed, push the start button, rotate the drum in the correct direction. If it starts up you probably need a new motor.
Watch your knuckles just in case it does start rotating.
GE GTS18GSSHMRSS Fridge Warm, Freezer Cold (Refrigerator & Freezer Repair)
by Pete Pliers 4/19/2023 4:41:06 PM(UTC)
maytag refrigerator MRT118FFFH01 2019 (Refrigerator & Freezer Repair)
by mbay14 8/11/2022 4:34:41 AM(UTC)
GE MONOGRAM ZIC360NMRH Ice Buildup (Refrigerator & Freezer Repair)
by Dawnv 10/11/2021 7:01:04 AM(UTC)
Maytag MRT311FFFZ00 thermistor chart & diagnostics mode (Refrigerator & Freezer Repair)
by scottaobe 2/1/2019 8:35:11 AM(UTC)
Whirlpool start relay 319NFBYY 2214067-53 FMR1L (Refrigerator & Freezer Repair)
by Paul222 9/4/2017 8:15:15 AM(UTC)
mr (Dryer Repair)
by bbeyler 10/23/2015 4:39:43 AM(UTC)
Mr (Washer Repair)
by TXHEART 12/12/2013 6:20:22 AM(UTC)
Mr B. (Washer Repair)
by emilio632 8/13/2013 4:58:55 PM(UTC)
Mr LES (Oven Repair (including Ranges and Cooktops))
by eulhagga 2/14/2013 1:25:39 PM(UTC)
mr. harry grupp (Refrigerator & Freezer Repair)
by harry grupp 1/19/2013 4:19:51 PM(UTC)
Mr Grit (Dishwasher Repair)
by MR GRIT 10/17/2012 3:25:11 PM(UTC)
mr. (Dryer Repair)
by andrewwhirlpool 3/19/2012 8:29:27 PM(UTC)
Mr clarence olsson (Washer Repair)
by COLSSON 12/19/2011 7:55:33 PM(UTC)
Comressor replacement (Refrigerator & Freezer Repair)
by adrianf 12/19/2011 2:18:50 PM(UTC)
Maytag Perfomra Won't Agitate (Washer Repair)
by tbuckle1 12/1/2011 5:22:36 AM(UTC)
