shalimar rentals
#1 Posted : Tuesday, January 4, 2011 11:10:40 PM(UTC)
shalimar rentals
looking for a generic brand to replace thermostat. are there any
#2 Posted : Wednesday, January 5, 2011 12:24:24 AM(UTC)
I do not know of any.
I am not sure why you are looking for a generic as the thermostat looks like it is in stock
Part number: AP2023080
Click on the picture for more info.
You could get the manufactures part number off the part and then use the internet to try and find a generic
Or
If you are trying to find a lower cost unit all I can suggest is the you remove the thermostat (be sure to label the wires) and take it to a local appliance parts supply house. If you get a knowledgeable counter person they may be able to supply a close match.
What is important is:
1. The type/size of knob shaft.
2. The mounting holes
3. The temperature range
4. If the unit has self clean
And perhaps a couple things I have not thought of.
Note: That most places will not let you return electrical parts so if you get something that does not do the job you may be stuck with it.
With luck perhaps someone has a cross reference for thermostats.
If they do I would be very interested in getting it.
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
KERS206XSS1 thermostat replacement part (Oven Repair (including Ranges and Cooktops))
by Guest 1/23/2024 3:59:52 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
Freezer Thermostat Replacment (Refrigerator & Freezer Repair)
by homerepairbyneed 5/29/2023 12:14:10 PM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Samsung Thermostat -- open or closed at room temp (Microwave Repair)
by Guest 8/29/2021 9:03:07 AM(UTC)
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Whirlpool thermostat not working (Refrigerator & Freezer Repair)
by tomok 5/17/2021 8:40:02 AM(UTC)
Wire two wire thermostat to coleman furn. (Oven Repair (including Ranges and Cooktops))
by Guest 4/4/2021 3:46:08 AM(UTC)
FDB750RCC2 Thermostat and Heating Element Connectors (Dryer Repair)
by beatrice109 3/26/2021 11:46:30 PM(UTC)
Amana Refrigerator Thermostat? (Refrigerator & Freezer Repair)
by yaworski 3/24/2021 10:42:55 AM(UTC)
Need thermostat control 216521100 (or alternative) for Frigidaire FFU20F9FW3 freezer (Refrigerator & Freezer Repair)
by MSStateDawg 1/21/2021 8:20:33 AM(UTC)
GE TFX27F stops cooling until reset via thermostat (Refrigerator & Freezer Repair)
by Gary Hall 12/2/2020 6:32:23 PM(UTC)
G.E. Replacement Thermostat (Oven Repair (including Ranges and Cooktops))
by StCrispin 11/23/2020 11:46:08 AM(UTC)
