I've exhausted all my limited electrical knowledge and need some help. Dryer stopped in mid-cycle (set on perm press, regular dry). I unplugged the cord, plugged it back in and it finished the cycle. Came back a few days later and the dryer will not even start now. Outlet is giving 240, cord is okay, start switch is working, door switch is working, moisture sensor is working, and the thermal sensors are working. I've tried manually pushing the drum to get it started but no response. I've tried all the different heat settings and the timed dry, but none give any reposnse. Any thoughts? :confused:
THIS FORUM IS DEAD!!!!!!! |
