rtripp5
#1 Posted : Tuesday, January 4, 2011 3:34:02 PM(UTC)
rtripp5
I've exhausted all my limited electrical knowledge and need some help. Dryer stopped in mid-cycle (set on perm press, regular dry). I unplugged the cord, plugged it back in and it finished the cycle. Came back a few days later and the dryer will not even start now. Outlet is giving 240, cord is okay, start switch is working, door switch is working, moisture sensor is working, and the thermal sensors are working. I've tried manually pushing the drum to get it started but no response. I've tried all the different heat settings and the timed dry, but none give any reposnse. Any thoughts? :confused:
#2 Posted : Wednesday, January 5, 2011 1:30:02 AM(UTC)
Replacement parts for FRIGIDAIRE FSE446RHS2 Frigidaire/electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131911100.pdf
You say that you have 240 volts but did you check both sides from Neutral for 120 volts. The motor runs on 120 volts (L1 to Neutral).
Have you checker the thermal limiter (fuse). I believe it is mounted by the heating coil. It should be 0 ohms.
Part number: AP2108182
Click on the picture for more info.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
