I recently received a new freezer door gasket for the above model and brand. However, here are no instructions on how to install it. Can you walk me through the process so I don't mess up the door.
Also, the end caps I received don't seem to fit tightly on the first shelf bar on the refrigerator door. The P/N is: 67213-2. I'm afraid because it won't hold properly the stuff on the shelf is going to fall off and break. What is the solution.
Thank you, Shirley Lance
oh boy!! .. first lay out the gasket on the floor and get all the wrinkles out of it. Use a hair dryer until it is relativly straight dont get it to hot or to close cuz you'll melt it another way is running it under hot water to remove wrinkles get that done first and let us know
Is it that difficult? Should I have a repair man do it? What about the end cap issue?
yes it is you can't just slap the gasket on and expect the door to close on the first try sometimes it takes a lot of adjusting to get it right I cant tell by the diagram what kind of end caps you have I would call a repairman have him do the gasket and tell you whats wrong with the endcaps.
I just replaced my refrigerator door gasket and I can't get it to seal all the way around. The top of the right side seals but the bottom has to be pushed in to get the seal. The top has a few spots that are not, but the hinged side is sealed all the way. I can not see whether the bottom is sealed or not. Is there something I have to put on the gasket or is it just not aligned properly? Thanks
