I'm searching for the gasket replacement part for an Imperial Heavy Duty Commercial Freezer (Model # UL2494ECW5). The door doesn't seal completely, and I get a build up of ice and frost on the inside of the freezer. I'm also looking for the replacement key for the lock.
Originally Posted by: bdcane  I'm searching for the gasket replacement part for an Imperial Heavy Duty Commercial Freezer (Model # UL2494ECW5). The door doesn't seal completely, and I get a build up of ice and frost on the inside of the freezer. I'm also looking for the replacement key for the lock. BDcane Did you ever find a replacement Gasket? Or the key? I have the same 2 problems. If I had the key, I could lock it tight. right now I have the door duct taped.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I am looking for the seal for model number UL4000ECW2
Groups: Expert
